Need OID for Spanning tree root status monitoring
Harsha Kumar
I have configured STP on two SG300-28MP 28-port Gigabit Max-PoE Managed Switch.
I could see one switch status as " This switch is Root for CST & IST masters in telnet.
Now I want to monitor the same ROOT status through SNMP.
Is this possible? if so, kindly share OID for monitoring the same.
Harsha
Aleksandra Dargiel
Hi Harsha,
It should be 1.3.6.1.2.1.17. Please let me know if it works.
Aleksandra
Thanks for your reply Aleksandra, The OID you mentioned is not showing any data.
Harsha
Hi Harsha,
Please try with snmp walk first to see the exact OID.
Aleksandra
