07-08-2010 11:24 PM
Hi all,
Just want to ask if it is possible to connect a cisco PoE switch to a cisco Non PoE switch?
The core switch will be a cisco Non PoE switch while the connected switch is a cisco PoE switch.
thank you....
Solved! Go to Solution.
07-11-2010 02:50 PM
You can disable PoE on an interface by invoking the command "power inline never".
Please don't forget to rate useful posts. Thanks.
07-08-2010 11:41 PM
Yes. IT's possible.
07-09-2010 12:43 AM
Is there will be no problem encountered with it?
Just want to be sure because we plan to have and implement it.
Another is there an option to disable it's PoE?
thank you
07-11-2010 02:50 PM
07-11-2010 09:50 PM
Thank you very much for the ratings.
