PoE fault on all the porst on CBS220
vix
I have one CBS220-48P-4G running the latest firmware 2.0.2.15 (upgraded March, 22nd 2025).
I see that all the ports (doesn't matter if a device is connected to the port) show a PoE fault.
The issue started at April 6th, and the first couple of weeks the issue was intermittent. Now the PoE is faulty.
I have threee CBS220-24P-4G (24 ports and not 48 - same firmware 2.0.2.15) and PoE works properly.
Is this a hardware issue?
All the switches have been installed last January (4 months ago).
@vix hi, can you share the console log. there is specific error codes to identify the issue. this can be a hardware issue. is data connection working well when you test with non PoE device?
note - if its purchased recently, you can ask support from the reseller.
Good luck
KB
Hi @Kasun Bandara
sorry for my late answer.
Yes, the non PoE devices work well. And PoE devices work well too if I power them with an external power supply (if available).
How can I get the console log?
Is it possibile through webserver or should I connect through RS232 or ssh?
Hi @vix,
does the switch properly display its power budget?
Using the CLI you can issue the command "show power inline" to get an output similar to the example below:
CBS220# show power inline
Power management mode: Class limit mode
Legacy device support: Disabled
Unit  Power  Status   Nominal     Allocated      Consumed     Available     Usage    Traps
                      Power       Power          Power        Power       Threshold
 1      On   Normal 375Watts   15Watts (4%)      5Watts     360Watts      95      Disable
Port    State      Status    Priority  Class  Max. Power (mW)  Alloc. Power (mW) Device
<list of port settings>
What does your device show especially for nominal power and available power?
You can also get the logs that Kasun mentioned via CLI using the command "show logging".
HTH!
@vix hi yes. you can connect to console port or check the device logs in GUI.
Good luck
KB
