Problem connecting to CISCO SF300-24PP
mmalaoui
I just acquired my first cisco SF300-24PP, the first thing I did was download a new version of the firmware that I installed without errors, but after restarting I no longer have access to the router
Cordially
7 Replies 7
balaji.bandi
Did you save the configuration before upgrading to new code ?
connect console cable and see is the device boot properly and what configuration it has now.
BB
thank you for your reply
I delivered the initial version of the firm via cable serial but the problem persists.
Cordially
can you more elaborate this problem
"I delivered the initial version of the firm via cable serial but the problem persists."
BB
I was able to reinstall via the console (cable serial) to install the firmware that came with the device I downloaded from the site CISCO
You need contact TAC for RMA i guess for the problem you reported. is that working before upgrade ?
below thread help you.
https://community.cisco.com/t5/small-business-switches/fatal-error-on-cisco-sg300-10mpp/td-p/2881507
BB
Yes the switch is new I got to know and start configuring it unfortunately I I made the decision to update when restarting the switch I no longer have access ..
