Problem with sf300-24 pp and cameras ip
PikoZza08
Hi good day.
My name is Mariana, I currently work with ip cameras, which are fed only by poe; However, sometimes these cameras are disconnected and when reviewing the ports it marks a lower voltage between 1600 and 1000 v., after that the port is lowered for a moment and then it rises again, when doing that the voltage tends to regularize, without However, it is already constant, on the other hand the firmware update was made in the cameras, and the same problem continues to occur. the configuration of the duplex was reviewed and it is in full of 100.
Can anybody help me?
ktonev
Hi Mariana,
We will probably need a show tech and some additional information like the model of cameras to provide some suggestions.
How often do you see this issue? Maybe a packet capture will be helpful too.
Feel free to call TAC and open a service request so an engineer can assist you with the above.
Kris
