Qurey about config VLAN on single satck Switch
sachinc01
Hi sir,
I will replace new switch SG500 L3 Gbps (x2) ,  Some VLAN config on SW1 need to config VLAN on SW2 (Switch2) also.
Need config VLAN again on SW2 or VLAN will replicate automatically.Both switch will be in stack.
Please guide.
Rs
Sachin
devils_advocate
Level 7
Level 7
The SG switches do not support VTP so you need to configure your vlans manually on each new switch.
jonrodr2
Hello my name is Jonathan and i am one of the Engineers here at the Cisco SBSC team. I apologize for the inconvenience with this unit.
I hope you are doing well, as you want to create a stack the unit that you select as the master will be the one you need to configure so all of the settings you change are going to be made via the master therefore you should be able to see the configuration of all of the switches  from just a single web interface and the vlans or any other setting you put there should appear by selecting the specific unit id on the web interface.
If you need further assistance feel free to call us at 1-866-606-1866 to open a ticket. thanks and have a great day.
