RADIUS-assigned VLANs on Catalyst 2960G
duckstoreadmin
I have a few 2960G switches I recently acquired, and I'm trying to get them to authenticate with a RADIUS server I'm running. The authentication process works fine, but though the RADIUS server is sending attributes as to which VLAN tag to use, the port stays a member of the VLAN it's set to (with "switchport access vlan ..."). I can set the guest and failed VLANs manually, but what I really want is to have the RADIUS server send VLAN attributes depending on which username or machine authenticates.
Looking through the documentation I don't see anything that specifically mentions this, so I'm afraid I purchased the wrong model. Anyone else know?
Glenn Quesenberry
I found this reference to RADIUS/VLAN assignments in the documentation here.  Have you seen/tried this reference yet (page 31 of the doc)?
Glenn Quesenberry
Yup, that's what I missed. I had everything configured, but I was missing the line "aaa authorization network...". Once I did this, everything worked as normal. Thanks for the help!
Glad to be of help, sorry for the delayed reply to your post!  This one must have gotten overlooked, my appologies!  We strive to provide answers and feedback as quickly as possible and usually is within 24 to 48 hrs during normal business hours.  Once again sorry for the delay!
Best Regards,
Glenn
Not a problem. I re-read the pertinent areas of the config guide and found what I was looking for.
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
