Setup IGMP snooping on SG 300-10
mschroeeer
i want to setup IGMP Snooping on the Managed Switch SG 300-10. I do it over the webinterface. Enable Bride Multicast Filtering, Forwarding Method IP Group Address and enable IGMP Snooping v3. In the local Network i stream up to 4 Multicast streams 239.1.1.1-239.1.1.4. The client vor the Multicast are IP setupboxes. If i connect PRTG Network Monitor over SNMP to see the Traffic on the ports i see that all Multicast streams are at every port. What is the false i do? I thought only the multicast stream that is shoosen at the client are forwarding and not all multicast streams. Can anyone help me. The IP STBs have only a 100Mbit network adapter and i have to muticast over 10 Streams (10Mbit per stream) over the local VLAN. So i think IGMP Snooping is the solution for me. Or need i also a Multicast router? Thank you very much. Best regards Michael from Germany
David Hornstein
Level 7
Level 7
In a real life triple play scenario, there will be a layer 3 querier on the network to query the multicast groups.
But did you elso enable multicast snooping on a per vlan basis?
regards Dave
