SF-300 24 2 subnet
ekajaekaja
I have 2 subnets and 2 uplinks
port g1 = 211.122.10.x
port g2 = 210.211.10.x
Can use 1 switch (sf-300 24)
assign port 1-12   up/down to g1
assign port 13-24  up/down to g2
Thank you.
David Hornstein
Level 7
Level 7
Hi Bob,
Again, here is the config, if you are using the latest firmware on the switch.;
User Name:cisco
Password:*****
Please change your password from the default settings. Please change the password
for better protection of your network. Do you want to change the password (Y/N)[Y] ?N
switch4cf1#config
vlan database
vlan 2
exit
hostname SF300-24
no passwords complexity enable
no snmp-server server
interface range fast13-24
switchport trunk native vlan 2
exit
interface gigabitethernet2
exit
interface vlan 2
name blue
exit
exit
SF300-24#copy run start
Overwrite file [startup-config] ?[Yes/press any key for no]...
regards Dave
