Showing results forĀ
Search instead forĀ
Did you mean:Ā
SF-300 TACACS+ Enable not working
craig.amos
Community Member
Running  SF-300 24 port non-POE (model # SRW224G4-K9 V01) firmware 1.1.2.0
Configured TACACS+ support for login via TELNET and SSH.
CLI allows connection to non-privledged mode on TELNET via TACACS, but when Iattempting to enter privledge mode the connection is rejected.
Had to set the enable mode to use the enable password which is less than ideal.
See attached file for commands
Is anyone else having this issue?
Flaming Badger
From CLI as a Priv15 user,
conf t
line telnet
no enable authentication
Hope this helps,
Iain.
I tried "no enable authentication" as recommended and get this in my local log:
%AAA-W-REJECT: New ssh connection, source 10.37.6.124 destination 10.36.12.247  REJECTED
When putting back on "enable authentication ssh" tacacs show user $enab15$ trying to login. Can I change it to use the username accessing the system?
