SF300-08 multiple default routes
daalliso@me.com
Hi Folks,
Having been a CSE in HTTS for several years, I will try to be thorough... :)
I have four DSL connections, live in the boonies, and trying to use this SF300-08 as a simple L3 router to load balance internet traffic across the four links.  I have attached the config and outputs.  It does not appear to be using the two active default “internet routes”.  I am only using two of the DSL connections at the moment.
Why does it only report the one default route when both routes, DSL-2 and DSL-4, are UP and configured?  What am I missing?
switch3c9863(config-if)#do sh run
config-file-header
switch3c9863
v1.4.8.6 / R800_NIK_1_4_202_008
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range vlan 1
qos statistics queues 1 all all all
hostname switch3c9863
no passwords complexity enable
username cisco password encrypted 95fbdb3e3d93f62058f8c18acd1d01130b16296c privilege 15
ip ssh server
ip ssh password-auth
ip ssh-client username cisco
encrypted ip ssh-client password AR0EvVLMGAD24At8AbZCRXJgLKYwPRAx3qYDTZqk8Go=
interface vlan 1
 no ip address dhcp
interface fastethernet1
 shutdown
 description To_DSL-1
 ip address 192.168.101.2 255.255.255.0
interface fastethernet2
 description To_DSL-2
 ip address 192.168.102.2 255.255.255.0
interface fastethernet3
 shutdown
 description To_DSL-3
 ip address 192.168.103.2 255.255.255.0
interface fastethernet4
 description To_DSL-4
 ip address 192.168.104.2 255.255.255.0
interface fastethernet5
 description To_loft_AP
 ip address 192.168.5.1 255.255.255.0
interface fastethernet6
 shutdown
 description To_playroom_AP
 ip address 192.168.6.1 255.255.255.0
interface fastethernet7
 description To_basement_AP
 ip address 192.168.7.1 255.255.255.0
interface fastethernet8
 description Direct_to_Dans_MacBook
 ip address 192.168.8.1 255.255.255.0
exit
ip default-gateway 192.168.102.1
ip default-gateway 192.168.104.1
switch3c9863(config-if)#do sh ip route
Maximum Parallel Paths: 1 (1 after reset).  <=== shouldn’t this show 2 paths?
IP Forwarding: enabled
Codes: > - best, C - connected, S - static
S   0.0.0.0/0 [1/1] via 192.168.102.1, 01:25:13, fa2   <=== only one default reported
C   192.168.5.0/24 is directly connected, fa5
C   192.168.7.0/24 is directly connected, fa7
C   192.168.8.0/24 is directly connected, fa8
C   192.168.102.0/24 is directly connected, fa2
C   192.168.104.0/24 is directly connected, fa4
switch3c9863(config-if)#do sh ip int
    IP Address        I/F    I/F Status  Type   Directed  Prec Redirect Status
                             admin/oper         Broadcast
192.168.5.1/24     fa5       UP/UP      Static  disable   No   enable   Valid
192.168.6.1/24     fa6       DOWN/DOWN  Static  disable   No   enable   Valid
192.168.7.1/24     fa7       UP/UP      Static  disable   No   enable   Valid
192.168.8.1/24     fa8       UP/UP      Static  disable   No   enable   Valid
192.168.101.2/24   fa1       DOWN/DOWN  Static  disable   No   enable   Valid
192.168.102.2/24   fa2       UP/UP      Static  disable   No   enable   Valid
192.168.103.2/24   fa3       DOWN/DOWN  Static  disable   No   enable   Valid
192.168.104.2/24   fa4       UP/UP      Static  disable   No   enable   Valid
switch3c9863#sh int counters
      Port       InUcastPkts  InMcastPkts  InBcastPkts    InOctets
      fa1             0            0            0            0
      fa2            1388          33           0          999446  <===
      fa3             0            0            0            0
      fa4             25           32           0          16107   <===
      fa5            1297          11           1          237621
      fa6             0            0            0            0
      fa7             0            0            1            64
      fa8             0            0            2           692
      Port       OutUcastPkts OutMcastPkts OutBcastPkts  OutOctets
      fa1             0            0            0            0
      fa2            1180          2            0          226931  <===
      fa3             0            0            0            0
      fa4             24           1            0           4038   <===
      fa5            1639          1            0         1161616
      fa6             0            0            0            0
      fa7             0            1            0           174
      fa8             0            1            0           174
       Ch        InUcastPkts  InMcastPkts  InBcastPkts    InOctets
      Po1             0            0            0            0
      Po2             0            0            0            0
      Po3             0            0            0            0
      Po4             0            0            0            0
      Po5             0            0            0            0
      Po6             0            0            0            0
      Po7             0            0            0            0
      Po8             0            0            0            0
       Ch        OutUcastPkts OutMcastPkts OutBcastPkts  OutOctets
      Po1             0            0            0            0
      Po2             0            0            0            0
      Po3             0            0            0            0
      Po4             0            0            0            0
      Po5             0            0            0            0
      Po6             0            0            0            0
      Po7             0            0            0            0
      Po8             0            0            0            0
switch3c9863#
Daniels-MacBook-Pro:~ danielallison$ traceroute www.cisco.com
traceroute to e2867.dsca.akamaiedge.net (23.199.33.130), 64 hops max, 52 byte packets
 1  192.168.5.1 (192.168.5.1)  3.079 ms  6.953 ms  4.890 ms
 2  192.168.102.1 (192.168.102.1)  2.553 ms  1.738 ms  2.576 ms
 3  75.160.214.254 (75.160.214.254)  30.270 ms  36.613 ms  47.445 ms
 4  rcmt-agw1.inet.qwest.net (71.32.31.1)  28.897 ms  50.436 ms  30.212 ms
 5  atl-edge-24.inet.qwest.net (67.14.14.162)  38.820 ms  39.962 ms  57.612 ms
 6  a23-199-33-130.deploy.static.akamaitechnologies.com (23.199.33.130)  39.754 ms  41.267 ms  41.973 ms
Dan
daalliso@me.com
Forgot to add that the APs are doing DHCP in their respective subnets with default gateways to the SF300 interface.  DSL modems have static routes to those subnets behind the SF300 and are routing as expected.
Would someone at Cisco please check to see if only one gateway can be active when in router mode.  It seems that is what I am seeing.
Problem: In switch mode although multiple default gateways can be configured through CLI, only the gateway with lowest value can be active. Hence, switches should not allow the CLI to configure multiple default gateways. (CQ147302)
Solution: When modifying the default gateway through CLI, delete the old one first.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf20x_sg20x/release_notes/R_1_4_8_6_RN.pdf
