SF300 to Cisco 2912 STP questions
JVezinat
We purchased a SF300. Topology as follows
Cisco 2921 (voice gateway) --->SF300 ---> Juniper SRX
I cannot seem to get the Spanning tree on the SF300 and the Cisco 2921 to recognize each other.  I have found posts where it's stated to put the SF300 into MST mode to be compatible with the RSPTV+ on the Cisco 2921.  Configs as follows:
Cisco 2921
TM8-BE6KS#sh span
 Bridge group 1 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 32768, address 7070.8bbf.c9d1
  Configured hello time 2, max age 20, forward delay 15
  We are the root of the spanning tree
  Topology change flag not set, detected flag not set
  Number of topology changes 5 last change occurred 14:46:42 ago
          from GigabitEthernet0/1
  Times:  hold 1, topology change 35, notification 2
          hello 2, max age 20, forward delay 15
  Timers: hello 1, topology change 0, notification 0, aging 300
 Port 5 (GigabitEthernet0/1) of Bridge group 1 is forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.5.
   Designated root has priority 32768, address 7070.8bbf.c9d1
   Designated bridge has priority 32768, address 7070.8bbf.c9d1
   Designated port id is 128.5, designated path cost 0
   Timers: message age 0, forward delay 0, hold 0
   Number of transitions to forwarding state: 4
   BPDU: sent 27116, received 0
 VLAN1 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 16384, address 7070.8bbf.c9d3
  Number of topology changes 1 last change occurred 00:58:38 ago
          from ucse1/1
 Port 100 (ucse1/1) of VLAN1 is forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.100.
   Designated root has priority 16384, address 7070.8bbf.c9d3
   Designated bridge has priority 16384, address 7070.8bbf.c9d3
   Designated port id is 128.100, designated path cost 0
   Number of transitions to forwarding state: 1
   BPDU: sent 1772, received 0
 VLAN100 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 32768, address 7070.8bbf.c9d4
          from ucse1/1
 Port 100 (ucse1/1) of VLAN100 is forwarding
   Designated root has priority 32768, address 7070.8bbf.c9d4
   Designated bridge has priority 32768, address 7070.8bbf.c9d4
SF300 CONFIG
SF300#sh span
Spanning tree enabled mode MSTP
Default port cost method:  short
Loopback guard:   Enabled
Gathering information ..........
###### MST 0 Vlans Mapped:
CST Root ID    Priority    0
               Address     70:1f:53:ea:a0:c2
               This switch is root for CST and IST master
               Hello Time  2 sec  Max Age 20 sec  Forward Delay 15 sec
               Max hops    20
  Name     State   Prio.Nbr    Cost    Sts   Role PortFast       Type
fa1       enabled  128.1     19       Frw    Desg Yes      P2P Intr
fa2       enabled  128.2     100      Dsbl   Dsbl No       -
fa3       enabled  128.3     19       Frw    Desg Yes      P2P Intr
fa4       enabled  128.4     19       Frw    Desg Yes      P2P Intr
fa5       enabled  128.5     19       Frw    Desg Yes      P2P Intr
fa6       enabled  128.6     100      Dsbl   Dsbl No       -
fa7       enabled  128.7     100      Dsbl   Dsbl No       -
fa8       enabled  128.8     19       Frw    Desg Yes      P2P Intr
fa9       enabled  128.9     19       Frw    Desg Yes      P2P Intr
fa10      enabled  128.10    19       Frw    Desg Yes      P2P Intr
fa11      enabled  128.11    19       Frw    Desg Yes      P2P Intr
fa12      enabled  128.12    19       Frw    Desg Yes      P2P Intr
fa13      enabled  128.13    100      Dsbl   Dsbl No       -
fa14      enabled  128.14    19       Frw    Desg Yes      P2P Intr
fa15      enabled  128.15    19       Frw    Desg Yes      P2P Intr
fa16      enabled  128.16    19       Frw    Desg Yes      P2P Intr
fa17      enabled  128.17    19       Frw    Desg Yes      P2P Intr
fa18      enabled  128.18    100      Dsbl   Dsbl No       -
fa19      enabled  128.19    19       Frw    Desg Yes      P2P Intr
fa20      enabled  128.20    100      Dsbl   Dsbl No       -
fa21      enabled  128.21    19       Frw    Desg Yes      P2P Intr
fa22      enabled  128.22    100      Dsbl   Dsbl No       -
fa23      enabled  128.23    19       Frw    Desg Yes      P2P Intr
fa24      enabled  128.24    100      Dsbl   Dsbl No       -
gi1       enabled  128.49    4        Frw    Desg Yes      P2P Intr
gi2       enabled  128.50    4        Frw    Desg No       P2P Bound (STP)
gi3       enabled  128.51    100      Dsbl   Dsbl No       -
gi4       enabled  128.52    100      Dsbl   Dsbl No       -
Po1       enabled  128.1000  4        Dsbl   Dsbl No       -
Po2       enabled  128.1001  4        Dsbl   Dsbl No       -
Po3       enabled  128.1002  4        Dsbl   Dsbl No       -
Po4       enabled  128.1003  4        Dsbl   Dsbl No       -
Po5       enabled  128.1004  4        Dsbl   Dsbl No       -
Po6       enabled  128.1005  4        Dsbl   Dsbl No       -
Po7  &n
