could use some advise on the best way of setting this up correctly
I am in the process of preping our network for the installation of an IP Camera based security system on it will be running within VLAN 600 in our network, and management would prefer that general users are not even aware it is there.
16 Cameras will all be running off two SF302-8P Switches that will be uplinked to our Cisco 2960 Access Switches. Due to port limitations I need to daisy chain the two SF302 Switches.
ACCESS-302-CA-01 - Ge1 uplinked to Port on ACCESS-03 (Cisco 2960)
On this switch Fe1-8 Need to be in VLAN 600 to communicated with the camera server which will be plugged directly into Ge2 on Access 302-02.
ACCESS-302-CA-02 - Ge1 Uplinked to Ge2 on ACCESS-302-01
Ge2 - connected to the Network Video Recorder.
I've defined the VLAN's in the switch and have VLAN 600 as Untagged for FE1-8.
how do I configure Ge1 and Ge2 on each switch to pass the appropriate VLAN conntent to the devices connected?
