SFE2000: default VLAN problem
scostantini
Hi, i have a problem with SFE2000.
I have 2 VLAN -> 1 (default) and 77
on port 1 i have VLAN 1 untagged
on LAG1 (G3+G4) i have VLAN 77T and 1U
on LAG1 i have attached a vmware esxi 4.1 that has management interface on 192.168.1.254 (VLAN 1) and virtual machine traffic data on VLAN 77 (tagged)
now ... from pc connected to port 1 ... i see 192.168.1.254 only for some seconds ... then i loose it (usualy i don't ...)
that's really strange ... seems something about defalut vlan 1
i could change all management port on new vlan 100 ... but ... is there any way to manage switch on a vlan different from default one (1)?
tks
David Hornstein
Level 7
Level 7
Hi Stefano.
I guess you have the latest version of code on the SFE2000.
Version 1 code was not as flexible as current code versions  and only wanted to use the predefined vlans.  Version 3 code made the switch so much much more flexible.
So if your switch isn't on version 3 code, go the link below and download the code via 'download software' option.
http://www.cisco.com/en/US/products/ps9980/index.html
I could check the manual, but I believe this layer 3 switch, you can select the management vlan when you are at version 3 of the code..
So if your SFE2000 is at version 3 code and under phone  warranty and still having issues, why not see if a SBSC technician can look at the switch to determine operator or switch error?  To get to a SBSC technician check the link directly below.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Hope this provides a direction for you to move forward.
regards Dave
