08-22-2022 05:21 AM
Hi All
I have Switch SG200-50P after the data center power down some ports is down and I can't access the switch, i try to search the internet for a reason but nothing helps, can any one help
Best regards
08-22-2022 10:23 PM
Switch Still powered on?
Have you connect the console on the switch what is the output on the console??
08-22-2022 10:33 PM
08-22-2022 10:46 PM
In this case, you should have to try with factor reset and check on the console what happens.
check with the TAC if the device is valid for RMA.
