SG200-08 - 802.1x Multi Session?
ericmfaden
Can it do it?  When I looked in the manuals there is a different manual for the SG200-08 apart from the rest of the 200 series.  So can it do multi session 802.1x authorization or do I need to get a SG200-18?
Thanks.
-Eric
jeffrrod
Level 4
Level 4
Dear Eric,
Thank you for reaching the Small Business Support Community.
Unfortunately the "Multiple Sessions 802.1X mode" is not present in the SG200-08 switches and it is on the SG200-18 an above 200 Series switches.
I hope this answers your question and please do not hesitate to reach me back if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
