SG200-08 switch NTP not working
niuoras01
I have an SG200-08 and can't get NTP to work.  The relevant lines of my configuration are below:
sntp client mode unicast
sntp unicast client poll-interval 16
sntp server pool.ntp.org enable
clock summer-time recurring USA zone EDT
clock timezone -5 minutes 0 zone EST
I can ping the above time server pool.ntp.org using the switch's built-in ping tool, meaning that default gateway and DNS are configured properly and the switch can reach the server.  It doesn't even try to synchronize (tcpdump doesn't show any NTP packets).
Any ideas?
Nick
Michal Bruncko
Level 4
Level 4
Hi Nick
didn't you missed this command?
clock source sntp
in your case switch does not have reason to reach NTP server as by default the clock source isn't NTP (but browser instead as I think).
Thanks, the clock source sntp command isn't in my config file although it is reflected in the Web GUI (the Clock Source radio button is correctly set to SNTP).
Anyway, I rebooted the switch and a few minutes later, it got the correct time via SNTP.  Looks like it just needed a reboot.  I work mainly in Linux so I'm not used to rebooting my devices to apply changes :-).
Nick
As default clock source is set to "browser", then you should see "clock source sntp" in your config file. If it wasn't included, then it wasn't applied into running configuration and NTP hasn't takes place. Could you please check (now after switch reboot) if that line is present in configuration? If yes, then there is some bug in WebGUI not applying NTP change to running configuration. Normally there shouldn't be reason to use reboot for enabling such feature like NTP client is.
