SG220-50P voice help needed
BADBADDOG
OK, clearly I am missing something, but this is my first time using both VLANs and Voice. I have read so much documentation that my eyes are glazing over.
Scenario: Cisco SG220-50P feeding a Sonicwall TZ600 firewall and then out to the internet through a Cisco 800 to a 20Mb connection. Currently have 35 PCs happily working away, all on one subnet with static IPs.
Goal: 25 of the ports on the Cisco will connect to a Polycom VVX410 phone (which support both LLDP and CDP) with a PC connected through the phone (which has a gigabit switch built in). Use a Voice VLAN to prioritize voice traffic.
The phones, the PCs, the firewall and the switch all have static IPs (not DHCP) on the same subnet.
Done:
Plugged in the switch, changed it's IP, otherwise stock. Plugged in a phone, set its IP to be on the same subnet as the PC and was able to make and receive calls successfully. PC attached to the phone worked fine.
Now I want to set up my VLAN
1. Added an OUI for Polycom phones
2. Checked that LLDP and CDP are enabled on the switch
3. Created a new VLAN (ID 100)
4. Set the Voice VLAN to be VLAN 100
5. Enables Telephony OUI for VLAN 100
6. Made my uplink port a member of both VLAN 1 (data – untagged ) and VLAN 2 (voice – tagged)
Let's test one port:
6. In “Port to VLAN” Port 24 is set to “trunk”, “untagged” for VLAN1, “tagged” for VLAN100.
7.Saved everything, rebooted the switch
8. In “port VLAN membership” table I see port 24 is a Trunk with 1UP and 100T. Lookin' good!!
9. Can still make and receive phone calls, PC connects to internet.
But……..
I check the dynamic MAC address table and see both the phone and PC are still both on VLAN1, clearly I am doing something wrong……………
Thanks in advance for any help!!
Zach S
Do you have LLDP-MED enabled? It's the extension to LLDP that helps the switch identify the endpoint as unified communications device, and then allocate it to the correct VLAN. I'm not 100% certain with the SG220, but on the Catalyst series phones will first appear on the data VLAN, then after negotiation will be allocated to the correct VLAN.
Page 84 of this document specifies how: http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf220_sg220/administration/guide/Sx220_AG_en.pdf
