11-25-2013 09:55 PM
Hello all!
i have the SG300-10 for my home network, and i have everything setup EXCEPT for static reservations via DHCP
how exactly would you configure those? i have several things configured for port-forwarding which requires static IPs. i already have pools configured with proper starting points to leave me room for the several reservations i need, but i dont want to make a mistake and blow something up.
below is my config, what commands do i use to add those? i want several in the 10 and 200 vlans. 1 for each of my wireless devices where i know the MAC, and also for my vlan 200 for my wired devices.
v1.3.5.58 / R750_NIK_1_35_647_358
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end <omitted>
no cdp run
spanning-tree mode mst
vlan database
default-vlan vlan 99
exit
vlan database
vlan 1,10,200
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
no lldp run
ip dhcp server
ip dhcp pool network User_200
address low 10.5.10.10 high 10.5.10.220 255.255.255.0
default-router 10.5.10.1
dns-server 68.105.28.12 68.105.29.12 68.105.28.11
exit
ip dhcp pool network Wireless_10
address low 10.5.11.10 high 10.5.11.15 255.255.255.0
default-router 10.5.11.1
dns-server 8.8.8.8 8.8.4.4
exit
no bonjour enable
bonjour interface range vlan 1
ip access-list extended U_Wireless_10
permit ip 10.5.10.0 0.0.0.255 10.5.10.1 0.0.0.255
permit ip 10.5.10.0 0.0.0.255 10.5.5.2 0.0.0.0
deny ip 10.5.10.0 0.0.0.255 10.0.0.0 0.255.255.255
deny ip 10.5.10.0 0.0.0.255 172.16.0.0 0.15.255.255
deny ip 10.5.10.0 0.0.0.255 192.168.0.0 0.0.255.255
permit ip any any
exit
hostname WesleyNetS1
management access-list Management
permit
exit
here is verification info:
[quote]
show ver
SW version 1.3.5.58 ( date 10-Oct-2013 time 17:15:41 )
Boot version 1.3.5.06 ( date 21-Jul-2013 time 15:12:10 )
HW version V02
dir
Directory of flash:
File Name Permission Flash Size Data Size Modified
backup-config rw 131040 13162 25-Nov-2013 21:55:24
backuplo rw 327600 26 10-Oct-2013 17:16:01
dhcpdb.sys r- 65520 -- 10-Oct-2013 17:18:12
dhcpsn.prv -- 65520 -- 02-May-2013 14:55:10
directry.prv -- 65520 -- 02-May-2013 14:55:10
image-1 rw 6976867 6976867 25-Nov-2013 21:15:32
image-2 rw 6976867 6976867 25-Nov-2013 21:26:41
mirror-config rw 131040 4351 22-Sep-2013 06:52:13
startup-config rw 262080 15333 25-Nov-2013 22:42:55
syslog1.sys r- 65520 -- 12-Nov-2011 23:34:37
syslog2.sys r- 65520 -- 12-Nov-2011 23:34:37
Total size of flash: 16252928 bytes
Free size of flash: 1119834 bytes
[/quote]
Solved! Go to Solution.
11-29-2013 07:52 AM
Hi Wesley, I believe for the static host, you need to configure all of the options. option 3 and option 6 for default router and dns respectively.
-Tom
Please mark answered for helpful posts
11-26-2013 10:28 AM
Hi Wesley, refer to CLI guide:
http://www.cisco.com/en/US/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/CLI_300_1_3.pdf
I think this is what you want:
Syntax
address ip-address {mask | prefix-length} {client-identifier unique-identifier | hardware-address mac-address}
no address
Parameters
address—Specifies the client IP address.
mask—Specifies the client network mask.
prefix-length—Specifies the number of bits that comprise the address prefix. The prefix is an alternative way of specifying the client network mask. The prefix length must be preceded by a forward slash (/).
unique-identifier—Specifies the distinct client identification in dotted hexadecimal notation. Each byte in a hexadecimal character string is two hexadecimal digits. Bytes are separated by a period or colon. For example, 01b7.0813.8811.66.
hardware-address—Specifies the MAC address.
-- please remember to rate and mark answered helpful posts --
11-26-2013 10:38 AM
Please refer to this post for any concerns
https://supportforums.cisco.com/thread/2217882
-Tom
11-28-2013 11:09 AM
Tom/Brandon/anyone
does anyone have a better solution for this?
or is this just a limitation of the IOS code that it does not allow DHCP reservation/assignments from within the vlan and static assigns are considered "outside" dhcp server?
that would mean a lot of duplicated work of assigning default router/dns/etc for every static host i want, which i am trying to avoid.
11-26-2013 12:04 PM
ok, so i was able to successfully add the static address...
show ip dhcp binding
DHCP server enabled.
The number of used (all types) entries is 1
The number of static entries is 1
IP address Hardware address Lease expiration Type State
10.5.10.9 01.54.42.49.d9.45. Infinite manual allocat
42 ed
now when i check the device, it does successfully have that IP address, but it does not statically assign it from the dhcp pool with the correct dns servers and default gateway.
i want to configure static dhcp assigns from within the pool if that makes sense
the device shows the ip, but no dns/default router, which means it has no internet connectivity.
11-29-2013 07:52 AM
-Tom
11-30-2013 03:01 AM
Tom,
i am afraid you are right, but that just feels wrong that "reserved" dhcp assignments cannot be done outside the dhcp scope/pool configuration, as it means you will be duplicating a lot of information.
seems like a real waste to me. i cant ever remember having to do this on enterprise cisco equipment.
11-30-2013 08:40 AM
If you add those params to the pool do you still have to manually add to each host? I can live with filling out option 3 & 6 in the pool via the gui or better yet through cli so you can add multiple dns's but per static host is a bit much. It should "import all" from the pool or better yet the server.
