SG300-10MPP on a large network
cwangskr
Can I use the SG300-10MPP on a lager layer 2 network ( lager than class C).  I have layer 2 switch with vlan1 ip is 141.225.215.224/22 and default-gateway is 141.225.212.1 and with this config I am unable communicate with switch or switch can't communicate with tacacs, radius, etc. I can't even ping the default-gateway from the switch, but if I change the vlan ip to 141.225.212.18/22 ( same class C range as default-gateway) every thing works fine.
Tom Watts
Hi Chandra, I could not recreate this. I have created a SVI at 141.225.212.1 /22 on a switch then I took a layer 2 switch and assign it 141.225.215.224 with gateway 141.225.212.1. This is able to ping successful from within either switch.
Do you have any special routing such as a VRF, VPRN, Route protocol (OSPF, BGP, etc) ?
-Tom
Please mark answered for helpful posts
http://blogs.cisco.com/smallbusiness/
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Tom,
141.225.212.1 (cisco WS-C4506-E) is running OSPF. I open a TAC with Cisco and they spend almost a half a day trying to figure out the problem. Finally they send me a new switch and it is doing the same thing. The PC's I connect to the switch have no problem communicating with network, only issue I have is management of the switch.
