08-04-2016 08:14 PM
So, I'll start off saying I am still a novice when it comes to VLANs and ACLs so if you wish to help me, have patience, please.
Anyways, the short story is that I would like to make a Management VLAN inaccessible to the rest of my VLANs on this switch. I understand that I will need to ACLs to accomplish this but either A) I am doing it wrong or B) what I am trying to do isn't possible. Here is my mock-up network info:
VLAN 101 = 131.111.1.0/24
VLAN 102 = 10.60.1.0/24
VLAN 681 = 131.186.0.0/24 (Management)
I can ping all my VLAN gateways on the switch using any VLAN so I know InterVLAN Routing is working like it is suppose to. The next step was to block VLANs 101 and 102 from being able to access VLAN 681. It looked easy enough and I thought I set it up right but I can still ping VLAN 681 IP address when I reside on either VLAN 101 or 102 which is a no-go. If you need any more particulars please let me know and I'll try to get it to you. Thank you in advance for assistance.
Solved! Go to Solution.
08-05-2016 04:46 AM
There are multiple ways to do this, but in it's simplest form:
access-list 100 deny ip any 131.186.0.0 0.0.0.255
access-list 100 permit ip any any
interface vlan 101
ip access-group 100 in
interface vlan 102
08-05-2016 04:46 AM
interface vlan 101
interface vlan 102
08-05-2016 05:42 PM
Wow, I feel like a noob. I was applying the ACL to the Management VLAN instead of applying it to the VLANs I didn't want to have access to it. I took a few tries on telnet but after digging through my CLI manual for some commands, I got it all working the way I want it. Again, thanks for the little nudge in the right direction.
For anyone else that comes to this thread, here is an example of what I inputted on Telnet/SSH to set up my ACL:
username:*****
password:*****
switchxxxx # config
switchxxxx(config) # ip access-list extended Computers
switchxxxx(config-ip-al) # deny ip any 131.186.0.0 0.0.0.255
switchxxxx(config-ip-al) # permit ip any any
switchxxxx(config-ip-al) # exit
switchxxxx(config) # interface vlan 101
switchxxxx(config-if) # service-acl input Computers default-action deny-any
switchxxxx(config-if) # exit
switchxxxx(config) # exit
switchxxxx # write
