SG300-10SFP transceiver compatibility
curtis03_2
Beginner
Beginner
Can anyone confirm is MFEFX1 (100BASE-FX) the correct SFP compatible with SG300-10SFP small business switch, to support 100Mb MM fibre 1310 nm wavelength, support up to 2 km?
The MFEFX1 quick start guide document does not list this switch as compatible only the SG300-10, SG300-10P and SG300-10MP devices are listed?
thanks in advance
Glenn Martin
Please find in the SG300 Series Data Sheet the supported Transceivers..
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html
Glenn
Mikel Ward
Beginner
Beginner
Hello, can you confirm if you ever tried this? I find the referenced document not specific enough for my liking (I am used to Catalyst switches where you cannot use 100Mbps SFPs in a GX/X/X SFP slot). Thank you
smailmilak
Enthusiast
Enthusiast
here it says that it's supported.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/quick_start/78-19252-01.pdf
"SFP ports are compatible with Cisco modules MGBT1, MGBSX1,
MGBLH1, MGBLX1, MGBBX1, MFELX1, MFEFX1, and MFEBX1, as well as
other brands of modules"
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Recognize Your Peers
