SG300: Differences between HW VID=1 and HW VID=2
telecastle
What are the differences between HW VID=1 and HW VID=2 in Cisco SG300 switches? I am about to purchase a couple SG300-10MPs, and I would like to know the answer to this question. Also, is it possible to determine what hardware version a switch is by looking at the back of the switch. If so, what does the label say exactly?
Thanks!
Tarquin Joseph
You will find what you need in the release notes for SW version 1.1.  See here:
http://cio.cisco.com/en/US/docs/switches/lan/csbss/sf20x_sg20x/release_notes/SxE_R1.1.pdf
The differences are listed under the section "Hardware Versions".  You can determine the hardware version by clicking Status > System > Summary. From the release notes - "Look at the lower portion of the screen under the graphic representation of the switch for the PID VID."
T.
Thanks, the Release Notes is where I learned about the two hardware versions of the SG300 Series switches. I was looking for more information, though.
I asked the question of the Product Manager (PM) probably 9 months or so ago,  as I had a early release version of the Switch.
The PM told me functionally they were identical, end of conversation between me and the PM.
regards Dave
There is a difference though.
VID=2 supports more VLANS, MAC addresses and multicast groups when using the upgraded firmware.
I thought that was clear from the document.  It's something to consider if you intend on using these switches in a cascaded design I suppose but I can't see you getting up to 4K MAC addresses using theses switches.
The only thing I can think of is that the VID=2 has more memory and processing power allowing it to handle the larger tables.
T.
