SG300 Multicast problem
gabrielsarbu
I have the following situation:
on SG300-28 with the latest firmware I have connected in interface G6 a multicast server, which generates 50 Mbps tafic(that is normal) on 224.1.2.1 port 1234
On interface G7 I have connected a windows machine in order to connect to stream using vlc on udp://@224.1.2.1:1234.
On switch I made the following configuration:
1.      Multicast ->
                       -> IP Group Address
2. IP Group Address -> Add -> Vlan 1, IP Multicast Group Address 224.1.2.1, Source IP Address: 192.168.1.7(multicast server)
                              -> Select 224.1.2.1 -> Details -> set G6, G7 to static
3. IGMP Snooping -> IGMP Snooping Status: Enable,On vlan 1 I activated IGMP Snooping Status and
4. On IGMP/MLD IP Multicast Group , it show domain 224.1.2.1 with only G7, not G6
and does not work
PS. Switch Ip addres is on the same network with multicast server(192.168.1.0/24)
What do I miss?
jeffrrod
Level 4
Level 4
Dear Sarbu,
Thank you for reaching Cisco Small Business Support Community.
I have found no documentation or related issues that can help us explain or fix your problem therefore I suggest you to contact the Small Business Support Center directly;
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Please do not hesitate to reach us back if there is any further assistance we may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
Tom Watts
Hi Sarbu, try using the MAC group, this will display all MAC address connecting if no specific MAC address is specified.
Setting up the VLC is also quite a chore, moreso than the switch
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
