05-26-2013 03:19 PM
I have the following situation:
on SG300-28 with the latest firmware I have connected in interface G6 a multicast server, which generates 50 Mbps tafic(that is normal) on 224.1.2.1 port 1234
On interface G7 I have connected a windows machine in order to connect to stream using vlc on udp://@224.1.2.1:1234.
On switch I made the following configuration:
1. Multicast ->
-> IP Group Address
2. IP Group Address -> Add -> Vlan 1, IP Multicast Group Address 224.1.2.1, Source IP Address: 192.168.1.7(multicast server)
-> Select 224.1.2.1 -> Details -> set G6, G7 to static
3. IGMP Snooping -> IGMP Snooping Status: Enable,On vlan 1 I activated IGMP Snooping Status and
4. On IGMP/MLD IP Multicast Group , it show domain 224.1.2.1 with only G7, not G6
and does not work
PS. Switch Ip addres is on the same network with multicast server(192.168.1.0/24)
What do I miss?
05-30-2013 11:01 AM
Dear Sarbu,
Thank you for reaching Cisco Small Business Support Community.
I have found no documentation or related issues that can help us explain or fix your problem therefore I suggest you to contact the Small Business Support Center directly;
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Please do not hesitate to reach us back if there is any further assistance we may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
05-30-2013 11:13 AM
Hi Sarbu, try using the MAC group, this will display all MAC address connecting if no specific MAC address is specified.
Setting up the VLC is also quite a chore, moreso than the switch
-Tom
Please mark answered for helpful posts
