06-09-2013 04:43 AM
I am currently working on a deployment for a small business center.
- 50 Offices where each should get its vlan incl. dhcp etc.
- 200 Ports total
- intervlan only for internet access and cisco hosted voice
When I try to add more DHCP scopes through the webadmin tool, I am getting a maximum of eight registered. Is there a way to increase this number?
Any suggestions are highly appreciated.
Thanks in advance.
Bjoern
06-10-2013 05:03 AM
Hi Bjoern, it appears the limitation of DHCP pools is 8. There is not a way to increase this. You may make a feature request if you wish to create a ticket with the small business support center.
-Tom
Please mark answered for helpful posts
06-10-2013 05:20 AM
Tom, thanks for your effort.
Just for my understanding: As I can add many more IP V4 Interfaces (sub interfaces), it is a software (firmware) specific issue?
Thanks!
Björn
06-10-2013 06:13 AM
Hi Bjoern, that is correct. It may also be difficult to classify as a firmware specific issue because the feature was added within the last couple months. I believe it is a limitation of the software.
-Tom
