SG500-52P x3, 1 Stack - downgrade firmware to upgrade boot image?
warren_stanley
Beginner
Beginner
Hi everyone
Hoping for some clarification, searching hasn't revealed anything clearly defined.
As titled, 3 SG500 switches in a stack (running in L3 mode), firmware info below
Firmware Version (Active Image): 1.3.5.58
Firmware Version (Non-active): 1.2.7.76
Boot Version: 1.2.0.12
I've read upgrading past v 1.3.5.58 is a no-go without upgrading the boot version. Will I need to downgrade active FW all the way back to  1.2.0.12, then upgrade Boot to 1.2.7.76, then re-upgrade FW to 1.2.7.76 and so-on and so on through each Boot/ FW [1.2.0.97, 1.2.7.76, 1.2.9.44, 1.3.0.59, 1.3.0.62, 1.3.5.58, 1.3.5.58, 1.3.7.18, 1.4.0.88]?
I'll take a backup of running config prior obviously, but  will my settings survive this?
Thanks for the input, I'd really like to not brick these switches!
Yiu Kay Lee
Firmware 1.4 Release Note:
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/Sx500/release_notes/R_1_4_RN.pdf
Thanks.
Yiu Kay Lee
Concentrix at Cisco
.:|:.:|:. CISCO | Yiu Kay Lee | SMB Pre-Sales | yiulee@cisco.com | Phone +1 (855) 354-7776
Yiu Kay Lee
Thanks.
Yiu Kay Lee
Concentrix at Cisco
Update - after re-reading the Cisco support documents and focusing on the section containing the Answer above. I backed up the running config (took some notes - just-in-case), upgraded the boot image to the version included in the 1.3.5.58 firmware download and rebooted the stack.
I then stepped though the 1.4.0.88 boot image upgrade, rebooted (to be sure), upgraded firmware, set active image and rebooted. All appears well. Thanks for the input!
1.4.0.88
1.3.5.58
1.4.0.02
I know this is an old post, but maybe there has been an answer since.
I have an SG500X switch and I for th life of me cannot get it to upgrade the boot version past a very old 1.2.0.12. There is no Boot code on Cisco's site for 1.2.0.97. There is FW but no boot code.
Core-B9-NET#sh ver
Unit SW version Boot version HW version
1 1.2.0.97 1.2.0.12 V01
Core-B9-NET#sh bootv
Unit Image Filename Version Date Status
1 1 image-1 1.3.7.18 12-Jan-2014 18:04:29 Not active
1 2 image-2 1.2.0.97 02-Feb-2012 10:12:46 Active*
Anytime I upgrade the boot version to the next one up 1.3.0.063.rfb it looks like it takes after a "wr mem" and then a "reload". But then if I reboot the switch a second time to make sure it actually took, it reverts back to boot version 1.2.0.12.
I have downloaded a couple copies of the FW and Boot but nothing seems to be working.
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Recognize Your Peers
