07-24-2018 11:05 PM - edited 07-26-2018 10:09 PM
Hi there.
I have Cisco SG500 in L3 mode.
Now I need to get ip addresses for vlans from two different external dhcp servers (for ex. 192.168.1.21 and 10.17.10.10).
For Cisco Catalyst it would looks something like this:
int vlan 100
ip addr 10.100.10.1 255.255.255.0
ip helper-addr 192.168.1.21
int vlan 110
ip addr 10.150.20.1 255.255.255.0
ip helper-addr 10.17.10.10
int vlan 120
ip addr 10.200.20.1 255.255.255.0
etc
Anyway to get this construction on SG500?
Thx
Solved! Go to Solution.
07-30-2018 11:11 PM
Hi again,
You can try with relay again. Remove the helper command and go to vlan interface (10.150.20.1):
switchxxxxxx# config switchxxxxxx(config)# interface vlan 30 switchxxxxxx(config-if)# ip dhcp relay enable switchxxxxxx(config-if)# ip dhcp relay address 10.17.10.10
*Note:
The operational status of DHCP Relay on an interface is active if one of the following conditions exist:
• DHCP Relay is globally enabled, and there is an IP address defined on the interface.
Or
• DHCP Relay is globally enabled, there is no IP address defined on the interface, the interface is a VLAN, and option 82 is enabled.
Up to 8 servers can be defined.
I'm adding you a link to CLI guide just in case:
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/Sx500/cli_guide/CLI_500.pdf
Hope it helps
Cheers,
Mike
07-27-2018 05:54 AM
You can try something like this:
for the example given (vlan 100):
switchxxxxxx(config)# ip helper-address 10.100.10.1 192.168.1.21
for the example given (vlan 110):
switchxxxxxx(config)# ip helper-address 10.150.20.1 10.17.10.10
for the example given (vlan 120):
switchxxxxxx(config)# ip helper-address 10.200.20.1 10.17.10.10
Cheers,
Mike
07-30-2018 10:52 AM - edited 07-31-2018 12:15 AM
Hi, Mike
Thank you for your reply.
Would you clarify, do I have to keep global ip dhcp relay settings?
when I've used one external dhcp server, I've configured:
ip dhcp relay address 192.168.1.21
on interface vlan xxx,
and it works fine. But I have to add one more dhcp-server right now.
Just I've added
ip-helper address 10.150.20.1 10.17.10.10, but it didn't work: /
07-30-2018 11:11 PM
Hi again,
*Note:
Or
Hope it helps
Cheers,
Mike
07-31-2018 12:31 AM
Hi, Mike.
Thank you for your help, it's really worked now.
BTW, there is hidden command 'ip dhcp relay address xx.xx.xx.xx' on vlan interface.
When I've added the command, I saw there were two ip dhcp relay servers in the general configuration:
ip dhcp relay address 10.17.10.10. ip dhcp relay address 192.168.1.21 ip dhcp relay enable
But there aren't appear any additional commands on the vlan interface:
interface vlan 150 ip address 10.150.20.1 255.255.255.0 ip dhcp relay enable
SG500, SW ver.1.4.9.4
