SG500x-24 Ports and stacking
HubaXUser1
we have one problem. We have two SG500X-24 Switches and we want to connect 4 x 10GBit/s and use also the stacking feature(with the other two ports)
But when we configure the switch with one of the two stacking modi in the webinterface, Port 3 and 4 aren't activated anymore? Is that a firmware limitation, or it isnt possible to use stacking and 4 port 10Gbit connection.
thank you and best regards,
Tarik
The two ports are shared.  It's either one or the other.  You should be able to stack over the 10GbE links between the units however.
