SG500x Routed Port
emetesh
Attempting to create routed port between a pair of SG500x.
Show run shows: set system queues-mode 4
GUI System Operation Mode: L3 and L2 mode
Interface has IP address assigned.
When I enter the no switchport command get incomplete command.  Options available are access, customer, forbiden, general, etc.
I currently have connectivity between the devices by leaving the link as a trunk  with all vlans allowed, but I need to stop broadcast traffic, as a routed link would accomplish.
Thanks for suggestions!
Lee Cox
Level 2
Level 2
You cannot create routing between a L3 500x switch and a L2 500x switch.  Both switches need to be in layer 3 mode.  If both switches are in layer 3 mode then you could create a common network VLAN between the 2 switches and route networks between them.  When a switch is in layer 2 mode there is no routing as routing happens at layer 3.
I guess I should add if you are using trunk ports you are not routing. You are just passing VLANs.
devils_advocate
Level 7
Level 7
From memory, you can just bang an IP address on the ports:
interface gi1
I think anyway.
