SGE2010 compatibility with windows 7 pro 64 bit?
cflmi
Is there any issues with accessing the browser based GUI using Windows 7  64bit on a SGE2010 switch? I took the switch home and tried on my XP 32bit machine and works fine, but no luck on any windows 7 64bit pc's. I have tried 3 different new pc's on this new switch and no luck at all. Any suggestions?
cflmi
Perhaps the manual should mention to set your IPv4 to 192.168.1.10
subnet to 255.255.255.0
Default Gateway to 192.168.1.1
After doing this, I can finally access the GUI.
I am disappointed in Cisco's documentation for this.
I hope the rest of my setup isn't so difficult.
also, No replies to my plea for help is also disappointing, Especially for the price I paid for all the Cisco hardware I purchased.
Hello Tom,
I am sorry we were not able to assist you with this before you found the solution. For more immidate assist I recommend calling us here at the SBSC. Below is a link which has the phone numbers you can use to reach us.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
