Small Business Layer 3 Switch?
mhamzahkhan
I was wondering if someone could tell me if there are any Cisco Small Business Switches which support dynamic routing protocols, and are all gigabit ports?
I saw the SFE2000, but this is a 10/100 ethernet switch, and only supports static routing from what I understand?
Hamzah
Leo Laohoo
Cisco 3560/3560E/3560X and 3750/3750E/3750X is a Layer 2/Layer 3 switch.
If you run IOS version 12.2(55)SE, OSPF v1 is supported on IP Base feature set.  Otherwise, you'll need to upgrade the feature set to IP Services(k) if you want full routing protocols.
