SNMP get the Untagged and Tagged VLANs on a trunk port Cisco SG350X
Hello All.
Please, I need help with this. I need to view which VLANs are on a trunk port and know which are tagged or untagged in the Cisco SG350X. What OID give me that information?
Thanks.
5 Replies 5
geoff.house
Hi @Sebastian_Diaz_20 - did you ever find out how to do this?
I'm just about ready to give up ....
marce1000
 - As far as I  understand it Cisco devices support only one untagged vlan on a trunk link , hence the information can be derived from the configuration and an snmp based effort would be overkill.
 M.
geoff.house
Thanks @marce1000 for your reply. For some reason I can't see it in the thread. Odd.
You're absolutely right.
I should have been more specific in my reply. I'm actually after the tagged vlans.
Looking at the supplied MIBs, the untagged vlans are available here:
1.3.6.1.4.1.9.6.1.101.48.62.1.1
... which works perfectly.
It looks like the tagged vlans should be listed this OID:
1.3.6.1.4.1.9.6.1.101.48.61.1.2
But those results give hex values of FF - ie the interfaces show that all VLANs are tagged - which isn't correct.
Older switches (SG300 etc) used to use a Hex String per VLAN - which we then had to decode to work out which interfaces tagged on each particular VLAN. The OID for this was:
1.3.6.1.2.1.17.7.1.4.2.1.4.0
Sadly this doesn't produce accurate results for the newer-style switches (SG350, SG500, SG550).
I'm slowly heading down the path of programatically logging into the device using SSH, then parsing the results - but this feels wrong.
Any help would be HUGELY appreciated.
Thanks!
Geoff
 - No specific solution for that , for the moment , note that you are not the original poster ; you may want to make new post/question with correct subject and content.
 M.
Of course. Thanks.
