返信
SNTP issue on CBS220
vix
I installed 4 CBS220 switches (24 and 48 ports) and I upgraded the firmware to v2.0.2.15.
I cannot fix two different issues with SNTP:
  1. SNTP works only if I specify the IP address of a server. Name resolution doesn't work for SNTP and so all the predefined list is marked as "Down" and the datetime is not updated
  2. The SNTP addresses that I added are lost after a reboot. The "save" icon doesn't appear after I add a new SNTP server IP and if I go to "File operations" I cannot have the list saved.
This is a main issue because after a reboot the datetime is lost, and I see some network issues (I suspect this is related to wrong datetime on the different devices).
Can you release a fix for this issue, please?
2件の返信2
vix
Sorry for pushing, but can I have a feedback on this report, please?
If I should contact the tech support, let me know
 - @vix   FYI : https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
  M.
