SRW2008MP noise level
Antoine92
Is it really dangerous to disconnect the internal fan ?
The noise level is very too high for a personnal home use.
Glenn Quesenberry
Yes!  Disconnecting the fan would not only cause the unit to overheat and fail but would also void any warranty you have the product.  There is a Cisco Small Business Managed Switch that is fanless and thus makes no noise, but it's only an 8-port switch.  Is a 24-port switch a requirement for your home use?  If not, take a look at the SFE1000P.
