SRW2024 - 1.2.2B
Dracarys
just had a switch fail to boot and it appears the firmware is corrupted, is there anyone out there by chance has a copy of the 1.2.2b or something similar so i can revise this switch? I have found some older firmware but they are unsupported or are corrupted.
worth a try to keep this off the scrap pile.
Cheers
Glenn Martin
Hello Dracarys
unfortunately being that the SRW2024 Gigabit Switch has reached End-of-Support and obsolete s/w is not available on Cisco.com. I do hope you can find it thru this member community. If not, please consider the range of Switch options available in the Small Business 200 Series and Small Business 300 Series families. Also, here's another piece of helpful information: https://salesconnect.cisco.com/#/program/PAGE-6508
Glenn
