04-11-2013 12:26 PM
I have an srw224 that when it is powered up the only thing that happens is all the LED's continuously blink. Does anyone know what the isuue might be?
04-11-2013 02:26 PM
Hi George, unfortunately there isn't enough information here. Is this a new switch? Old switch? Was it working before?
Blinking power LED means the switch is probably getting DHCP or expecting DHCP. Solid power light should indicate static IP. If it is orange it indicates a problem.
What is the issue you're experiencing?
-Tom
Please mark answered for helpful posts
04-11-2013 02:46 PM
This is an older switch I have used before. When it is powered up all the LED's flash continuously. I cannot get into the switch via the console or by http. It is a 24 port with 2 Gig ports and a mini gig port. it's as if the switch is cycling through the post but doesn't complete it.
04-11-2013 02:51 PM
The only hope for that box would be able to console to it. If the console doesn't respond or work then it is dead.
-Tom
04-11-2013 02:58 PM
Nothing works for it. Cannot get in any way. thank you for your help though.
