Stacking!!
jarar_m01
I want to know if its possible to stack my old switch WS-C3750G-12S-S with WS-C3750X-12S-S ?
Also can some one tell me WS-C3750G-12S-S can be stacked with which other switches ?
Any help will be appreciated.
Thanks & Regards
Jarar.
devils_advocate
Level 7
Level 7
You can stack 3750G and 3750X switches but you will lose the Stackwise+ ability so your stack ring will run at the lower stackwise speed.
I believe the IOS' need to be the same, I have read the 3750G will need to be at least 12.2(53) in order to support the 3750x series switches.
You will also need to double check the licences.
devils_advocate
Level 7
Level 7
Yes thats true, can you suggest me what is the best thing i can do.. coz WS-C3750G-12S-S is EOL and we need to stack. Also 3750X is expensive.
