Star-topology with five SG350X-48P and one SX550X-12F 12-PORT 10G
ian.thorpe
Is it possible to trunk five SG350X-48P ethernet switches with an SX550X-12F as center switch in a star topology? The connections between the ethernet switches and the center switch are realized with GPICs transceiver SFP10GSR for multimode optical fibre.
Thank you for your support.
yes you can use it like star using compatible 10G fiber transceivers with Multi mode cables.
rate this and mark as answer if solved your concern
Good luck
KB
Good luck
KB
Good luck
KB
Good luck
KB
