06-23-2024 08:54 AM - edited 06-23-2024 08:54 AM
Hello all,
i have a SX550x All is ok on 10gbe, but i recently connect a 2.5gbe card and i see only 1gbe...
My question is stupid but is it normal?
If yes, i need another swith compatible 1, 2.5, 5 and 10gbe?
thx a lot
06-23-2024 09:21 AM
- How do you define connect , is it external to the device ?
- Is the card compatible with the SX550x
- Check logs on the SX550x upon initial use and connecting this card and also when trying to use it.
M.
12-08-2024 08:58 AM
sorry to be late.... very late.
Well i still i my issue.
My rj45 cable is cat8, my computer is connected to the swith and detect 10g perfectly. however I have 2 elements with 2.5 and 5 GB cards and the swith detect 1000m in the port management part of the switch with the same cable
