Trouble deleting image from flash Cisco SF 300-24
backuplo                rw       851760      26      30-Aug-2011 10:47:28
directry.prv            --       65520       --      30-Aug-2011 10:46:37
image-1                 rw      7274496    7274496   30-Aug-2011 10:46:37
image-2                 rw      7274496    7274496   30-Aug-2011 10:46:37
mirror-config           rw       131040     15725    20-Oct-2012 17:18:41
sshkeys.prv             --       131040      --      30-Aug-2011 10:48:01
startup-config          rw       131040     15487    10-May-2013 12:21:19
syslog1.sys             r-       65536       --      10-May-2013 12:12:14
syslog2.sys             r-       65536       --      10-May-2013 12:12:14
#show bootvar
Image  Filename   Version     Date                    Status
1      image-1    1.0.0.27    28-Apr-2010  13:33:55   Not active
2      image-2    1.1.1.8     30-Aug-2011  10:46:34   Active*
"*" designates that the image was selected for the next boot
SF300#delete flash://image-1
Delete flash://image-1 [y/n]? y
Delete operation is not permitted on file flash://image-1
Am I missing something?  I'm not terribly familiar with the 300 series CLI.
Thanks in advance.
2 Accepted Solutions
Tom Watts
Nicholas, delete the image from flash is unsupported. (In other words, you can't).
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
6 Replies 6
Tom Watts
-Tom
Tom,
Thanks for the input.  If deleting the image that is not being used is unsupported, then how does one update the image on these devices?  If i can't delete one of the images I don't have enough room to add the newer image.
~Nick
It will over write to the non-active image.
-Tom
Seems I'm not able to overwrite that image Tom.  Any ideas?
SF300#$ftp://(ipaddressomitted)/Sx300_FW_1.3.0.62.ros flash://image-1
Overwrite file [flash://image-1] ?[Yes/press any key for no]....Cannot delete file image-1:nThe file is in use.
SF300#show bootvar
SF300#show ver
SW version    1.1.1.8 ( date  30-Aug-2011 time  10:46:34 )
Boot version    1.0.0.4 ( date  08-Apr-2010 time  16:37:57 )
HW version    V01
I realize this is an old thread, but i am stuck with an old firmware on the switch as the one i have that i am trying to make active wont take, as the bootloader wasnt installed prior to this new version. Now i cannot upload a bootloader so it will work, as there is no room. I have tried everything, I am not sure why upgrading firmware is such a challenge. Surely there must be a way to clear the inactive image.
Please help.
