Upgrade of Cisco Catalyst 3750G 24T
nicolastailler
I want to upgarde a Cisco Catalyst 3750G 24T because I can't see the web interface.
I checked the documentation and see a lot of videos on the net.
I downloaded the new firmware c3750-ipbasek9-mz.122-55.SE9.bin
I downloaded a tftp software and putted my ip adress on it.
I connected the Cisco by console and launched Putty by serial.
I sended en for grant my right access.
I sended my password
and tapped :
copy tftp: flash:
it asks TFTP Ip, i gave it
10.0.0.45
file name
i gave it
and after It sended me when it must put it and i sended the same name.
And then It works few seconds and the cisco says error ... time out.
I've tested with W8, W7 and a lot of tftp server. I disabled my firewall.
The password is the default password. It is a problem ?
Can you help me ?
Nicolas
Brandon Svec
Level 7
Level 7
Did you confirm you can ping 10.0.0.45 from your switch to your PC with ftp server?
Also, if your PC has a second network connection (like wireless) you should try to disable it because the ftp server may bind to the wrong interface.
-- please remember to rate and mark answered helpful posts --
