VLAN & DHCP Server setup for voice & Data
tjb1234567
We have a single SGE2010 in layer 3 mode switch with a Server 2008 DHCP server.
We will be implimenting a Voip netowork where the PC's connect to the voip phone. I would like to create another vlan - 10. I have created the vlan and assigned the IP on the swtich.
Routing seems to be working. I can ping both IP addresses of the switch on either vlan.
I cannot get DHCP working. In the SGE switch I have enabled DHCP Relay, enabled option 82, set my DHCP Interface as VLan1, and specified the DHCP servers IP address. On the ports I have set the port where the DHCP server connects to as a trunk port with Vlan 1 untagged and vlan 10 tagged. I have set the ports where the phones connect as a trunk port with vlan1 untagged and vlan 10 tagged.
The PC connected to the phone gets an IP from the DHCP server just fine.
The phone does not get an IP address
The scope has been set up on the server.
Any help is appreciated.
tjb1234567
Uh, I spent HOURS on this. I entered the interface for the DHCP server incorrectly. I thought you entered the interface the DHCP server was on.
