Voice VLAN 10 and Data VLAN 20 | same switch port | laptop over ip ph
Hi All
Please help me, guys.
I have configured the cisco business 350 series switch as below.
My requirement
I need to carry both VLANs since I'm using a Laptop over an IP phone
So used the CMD in all switch ports "switchport general allowed VLAN add 30,80 untagged"
It's working fine too.
But the problem is when I unplug the IP phone and connect the laptop directly to the same port, it does not work.
what is configured
interface GigabitEthernet2
switchport general allowed vlan add 30,80 untagged
What its showing after I connect the port
storm-control broadcast level 10
storm-control multicast level 10
port security max 10
port security mode max-addresses
port security discard trap 60
spanning-tree portfast
spanning-tree bpduguard enable
switchport mode trunk
switchport trunk allowed vlan 1,30
macro description ip_phone_desktop
!next command is internal.
macro auto smartport dynamic_type ip_phone_desktop
Thank you in advance for help
Vinoth Kumar
vinothsaravanan148@gmail.com
Aleksandra Dargiel
hello Vinoth,
actually it looks like that the active mode is trunk:
you can double check this by displaying output show interfaces switchport <gi2> and please check with is next to the Operational Mode:....
this would give you an idea what the the actual mode as switch accepts so called shadow configuration as well...
also you may want to check show mac address-table interface gi2
this would give you an idea in which vlan the laptop MAC address actually IS.
Alex
