10-16-2019 11:19 AM
I know the term length commands for a catalyst, but SG switches don't have a term length command. So how do I get the output to pause so I can read it? Like when I do a sh tech-support it scrolls all of the info off the screen, how can I get it to pause in between so I can read it for SG switches.
10-16-2019 08:22 PM
Have you tried: terminal datadump command?
10-17-2019 02:26 PM
No because I want the pause.
Would the command be no terminal datadump?
10-25-2019 07:38 AM
Hi Michael,
As of now terminal length command is not available for SG switches however capturing the tech-support output to a text file is one option you may try, in case that helps you to review the output. One common application is putty for that purpose.
