When should I enable STP?
rdrisaldi
Beginner
Beginner
I have my network with serie 300 switches. One is working in layer 3 mode and all others switches are in layer 2 mode.
I dont have redundant path between switches. Should I enable STP? or is not necessary?
Thanks a lot.
Hi Ruy,
It is rare for STP to cause problems. There are a few rare cases that it will cause a problem but overall having STP enabled should not impact your network.
I would recommend double checking everything on your network before disabling STP. It only takes one missed cable and your whole network will freeze in a broadcast storm.
Daniele Giordano
Collaborator
Collaborator
If you don't have redundant paths, STP is not necessary but can be useful to prevent problem do to accidental loop.
Regards.
Daniele, Thanks for you reply.
If I dont have redundant path but I anyway enable STP could be some problem or its ok?
thanks!
Hi Ruy,
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Recognize Your Peers
