Showing results forĀ
Search instead forĀ
Did you mean:Ā
WS-C2960-8TC-L - Firmware upgrade not possible
B2B Team
Good day All.
I need your support regarding the firmware update procedure for my Cisco WS-C2960-8TC-L.
I'm using it just for test purposes.
At the moment the software version is 12.2(35)SE5.
In the official page (link) the most updated version available is 15.2.7E11: I've downloaded it on my computer TAR format.
I've tried to update to 15.2.7E11 in 2 ways:
1) From browser interface
         - It gets stuck without errors at the 1st point ("Loading of the TAR file into the switch")
2) From Cisco Network Assistant -> Maintenance -> Software update -> Upgrade Settings -> Mode: standard
         - In the status it appears the error "Failed to execute the command archive download-sw /overwrite /http iosFile"
I have not any TFTP, FTP or RCP server.
I've already disabled the antivirus and the firewall on the PC.
Could you please help me?
Thanks a lot in advance.
Best regards.
Francesco
Leo Laohoo
I can guarantee 100% (because I've tried it) that 15.2(7)E-train is not compatible with plain 2960.  Load it and the several of the drivers will crash because of incompatible components in the motherboard.
12.2(55)SE12 and 15.0(2)SE11 are the only two trains/versions I'd recommend for the "plain" 2960.
6 Replies 6
M02@rt37
Hello @B2B Team
Do you have console access ?
Post the complete output to theses 2 following commands:
- sh version
- dir
Best regards
B2B Team
Hello M02@rt37,
thanks for helping me.
As requested:
- sh version
- dir
Just looking forward for your thoughts.
Best regards.
Francesco
OK @B2B Team
You don't want to upgrade via CLI ?
Best regards
Leo Laohoo
Hello @Leo Laohoo
Thanks for that clarification.
Best regards
Hi Leo Laohoo,
I've successfully upgraded to 15.0(2)SE11 via browser.
Thanks a lot for your precious help.
I wish you an awesome day.
Best regards.
Francesco
