07-17-2016 09:56 AM - edited 03-08-2019 06:39 AM
07-17-2016 10:25 AM
I have never used the DAC cable with the 3750-E series but according to the data sheet as long as the switch is running IOS version 12.2(55)SE1 or later the cable is supported (see links)
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html#_Toc455743811
Do we need to select a 10 GE NIC where the mfg states support for direct attach copper (DAC) or does SFP+ automatically support DAC?
If the switch supports it than it should automatically detect the cable and SFP+.
07-17-2016 03:01 PM
Re DAC, my concern is the NIC not the OneX Converter. As you say, the docs confirm the converter will recognize the twinax cable.
Bob
