Highlighted
Beginner
10 gig connectivity on our 6506-E
we have a older WS-C6506-E we use for our Security System.
Mod Ports Card Type                              Model              Serial No.
  3   48  CEF720 48 port 1000mb SFP              WS-X6748-SFP       SAL11380SR4
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAD09280ATY
  6    2  Supervisor Engine 720 (Hot)            WS-SUP720-3B       SAL092858HY
I would like to add a WS-X6708-10GE to provide 10 gig to a 2960s switch the new Security Servers we be place.
At present the 6506 has:
system power redundancy mode = redundant
system power total =     1153.32 Watts (27.46 Amps @ 42V)
system power used =       918.12 Watts (21.86 Amps @ 42V)
system power available =  235.20 Watts ( 5.60 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-2500W       1153.32 27.46  OK     OK     on
2    WS-CAC-2500W       1153.32 27.46  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6506-E-FAN       98.70  2.35  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
3    WS-X6748-SFP        254.94  6.07   254.94  6.07  on    on
5    WS-SUP720-3B        282.24  6.72   282.24  6.72  on    on
6    WS-SUP720-3B        282.24  6.72   282.24  6.72  on    on
If i move the Power supplies to a 220volt circuit  and with the present hardware, should the new
10gig card work?
1 ACCEPTED SOLUTION
Highlighted
VIP Expert
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Will in work in with your current configuration?  No!
The 6708 will draw about 445 watts, which you don't have available.
However, if you change from power redundancy to combined power, then it will work.
It will also work, with power redundancy, if you move to 220V.
NB: above based on Cisco's Power Calculator
3 REPLIES 3
Highlighted
Hall of Fame Expert
You shouldn't need to change the power input to put a x6708 in the chassis.  If you are using 120volt it should still work fine as long as you have enough power on the PSUs.
Highlighted
VIP Expert
Disclaimer
Posting
Highlighted
Beginner
thanks for the responses!
Content for Community-Ad
