100G connectivity issue from ASR1006-X with C9300X-24Y-E
imranul hoque
HI,
i want to establish 100G connectivity between ASR1006-X with C9300X-24Y-E.
At C9300X-24Y-E side i have chose Catalyst 9300 2 x 40G/100G Network Module QSFP+/QSFP28 (part number C9300X-NM-2C)
What exact components (RP, SP, Line card slot, fiber sfp module etc.) are required at ASR1006-X side to establish 100G connectivity.
please help/suggest.
br
imran
marce1000
 - Use this app  to check and or verify compatible SFP's for the involved platforms (according to speed needed) :
                                                  https://tmgmatrix.cisco.com/
 M.
imranul hoque
can we use two rp3 (for redundancy) and one esp 200 (for 200Gbps thoughput) ??
Look at the document :
  • 100 Gbps high density, modular Ethernet linecards (ASR1000 MIP-100)
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/1009X_1006X/1009X_1006X_html/b_ASR1006X-1009X-HIG/b_ASR1006X-1009X-HIG_chapter_01.html
BB
